The Latest UXPin Updates – Summer 2023
We’re reviving our series at UXPin’s blog to inform you about new features, updates, and upcoming product releases. In this one, you’ll read about new ways of adding and styling links, using eye-dropper, and editing components’ props.
🔍 Access specs for grouped elements
Aside from inspecting components one by one, you can now get the specs for borders, radius, and CSS of grouped elements, including the ones that were added with Auto Layout.
🔗 Enjoy a greater control over linking
Add a clickable link on a specific word, a string of words, or even a whole paragraph within one text box. Select the text you want to add a URL to or link it to any other page within the prototype.
That’s not all! Style the hyperlink to match your design system. Make your prototype hyperrealistic from now on. Try it now.
👁️ Smoother Eye-Dropper
Enjoy a faster and more intuitive Eye-Dropper. When picking colors, you can select an Eye-Dropper once and adjust the colors. No need to be constantly reselecting it. That’s one less step in designing.
🔢 Merge: Set up decimal places in number props
Hey, for those of you who use Merge tech, for coded components with number props, such as grid (flex), you can now add numbers with decimal places to make your prototypes even more accurate.
🖱️ Merge: Embed JSX code into a chosen element
Create advanced Merge components faster. Select a Merge component and pass its JSX code into the node property of another element. This works on UXPin’s canvas and in the library and it will come in handy when building prototypes.
🫣 Merge: Hide nested components
Nesting components? If you want to hide components that are nested together, do that without the need of ungrouping them or removing them entirely. Add toggle interaction to hide layers in nested components.
Give new updates a try in UXPin. Sign up for free and build an interactive prototype today.
