15 Best Design System Examples in 2026: Real-World Systems Worth Studying
Explore 15 real-world design system examples from Google, Shopify, IBM, Apple, and more. Learn what makes each system effective, how to evaluate design systems, and how to start building your own.
A design system is a collection of reusable components, design tokens, guidelines, and code that product teams use to build consistent, on-brand interfaces at scale. The strongest systems act as a single source of truth — bridging the gap between design intent and production code so every screen ships with the same quality, accessibility, and brand coherence.
Below, we break down 15 design system examples from companies that have publicly shared their approach. For each, you’ll find what makes it notable, what you can learn from it, and links to explore further. We also cover what a design system is, why companies invest in them, and how to evaluate whether a system is well built.
What Is a Design System?
A design system is a comprehensive set of components, rules, design tokens, and documentation used to build a coherent, on-brand interface for a product. It encompasses everything a product team needs — from color palettes and typography scales to coded UI components and accessibility guidelines.
Design systems aren’t only for designers. They are equally valuable for developers, because they contain front-end component libraries, API references, implementation documentation, and code snippets alongside the visual design guidelines. When properly structured, a design system serves as a centralized layer connecting design decisions to production code, enabling consistent and scalable interface development.
Think of a design system as a living product that combines a UI kit, a coding reference library, design guidelines, and governance rules into one shared resource the entire product organization relies on.
Design System vs. Pattern Library vs. Style Guide
These terms are often confused. Here’s the distinction:
- Design system: The full stack — principles, design tokens, components, patterns, code, accessibility rules, governance, and a contribution model.
- Pattern library: A collection of reusable UI patterns (form layouts, navigation structures, card patterns) and usage guidance. A pattern library is typically part of a design system, not a substitute for one.
- Style guide: Brand and visual language documentation — logo usage, color definitions, typography, and tone of voice. A style guide supports a design system but doesn’t cover components or code.
Why Companies Build Design Systems
Companies like Google, Shopify, IBM, and Salesforce invest heavily in design systems because they solve real organizational problems:
- Consistency — A design system acts as a single source of truth, ensuring every product surface looks and behaves the same way.
- Transparency — Developers can use design system components directly, without interpreting design decisions from static mockups.
- Scale — Designers build prototypes faster, and developer handoff becomes dramatically simpler when everyone works from the same components.
- Reusability — Shared components reduce duplicated effort across products, platforms, and teams.
- Quality — Centralized accessibility, interaction, and performance standards get baked into every component, raising the quality floor for the entire organization.
For example, PayPal‘s 5-person UX team supports 60+ products and over 1,000 developers using a shared design system with UXPin Merge. This allows both designers and developers to work with the exact same interactive components — eliminating the disconnect between design mockups and production code.
The Benefits of Creating a Design System
With a well-built design system in place, organizations can:
- Improve team velocity — Designers don’t redesign common patterns from scratch; developers don’t rebuild solved components. Enterprise teams using code-backed design systems with UXPin Merge report up to 50% reduction in engineering time.
- Minimize design-dev miscommunication — When both sides work from the same components, there’s no ambiguity about spacing, behavior, or interaction states.
- Reduce UX debt — A shared system catches inconsistencies early and prevents them from compounding across products.
- Accelerate prototyping — With UXPin Forge, teams can generate fully interactive prototypes from text prompts using their actual design system components — going from idea to testable prototype 8.6x faster than traditional workflows.
- Ship accessible products by default — Accessibility standards (WCAG compliance, keyboard navigation, focus management) are encoded in the component library once and inherited everywhere.
How to Evaluate a Design System
Whether you’re auditing your own system or studying others, use this checklist:
- Coverage: Does it include core foundations (color, type, spacing tokens), a component library, and common patterns?
- Documentation clarity: Are there clear purpose statements, usage examples, do/don’t guidance, and platform-specific notes?
- Accessibility: WCAG mapping, keyboard behavior, focus states, color contrast guidance, and testing notes?
- Code delivery: Install instructions, package names, supported frameworks, versioning, and a changelog?
- Theming and tokens: Clear token names, scales, and documentation of how tokens map to components and themes?
- Governance: Defined roles, decision-making processes, backlog management, and release cadence?
- Contribution model: How can teams propose changes, what are the review criteria, and what are typical acceptance timelines?
- Adoption proof: Real examples, screenshots, or references from shipped products that use the system?
1. Google Material Design 3
What it is: Google’s open-source design system, now in its third major iteration (Material You / Material Design 3). It powers Android, Google apps, and thousands of third-party products.
Why it’s notable: Material Design 3 introduced dynamic color — a system that generates an entire color scheme from a user’s wallpaper, creating personalized theming at system level. It also includes a comprehensive token system, adaptive layouts for all screen sizes, and robust accessibility documentation.
What you can learn: How to implement a token-based theming architecture that scales across platforms. Material Design’s elevation system (using tonal color rather than shadows in M3) is a masterclass in creating visual hierarchy without relying on drop shadows.
Explore: m3.material.io
You can design with Material UI components directly inside UXPin using the MUI library for Merge — the same production-grade React components developers use in code.
2. Shopify Polaris
What it is: Shopify’s design system for building merchant-facing admin experiences. Polaris covers design foundations, a React component library, content guidelines, and accessibility standards.
Why it’s notable: Polaris is one of the most complete public design systems. Its content guidelines are exceptionally detailed — covering voice, tone, grammar conventions, and even how to write error messages. The token system is well documented and the component API is clean and consistent.
What you can learn: How to integrate content guidelines into a design system (not just visual and code standards). Polaris demonstrates that a design system’s value extends beyond components to include how you communicate with users through the interface.
Explore: polaris.shopify.com
3. IBM Carbon Design System
What it is: IBM’s open-source design system for products and digital experiences. Carbon supports React, Angular, Vue, Svelte, and web components — making it one of the most framework-agnostic systems available.
Why it’s notable: Carbon’s data visualization guidelines are best-in-class. It includes a dedicated charting library with accessibility-first defaults, and the system’s 2x grid is a flexible spatial framework that works across complex enterprise UIs. Carbon also has a well-documented contribution model.
What you can learn: How to build a design system that serves complex enterprise products. Carbon’s approach to grid, spacing, and data-dense interfaces is highly transferable to any B2B or SaaS product.
Explore: carbondesignsystem.com
4. Apple Human Interface Guidelines (HIG)
What it is: Apple’s comprehensive design guidance for building apps across iOS, iPadOS, macOS, watchOS, tvOS, and visionOS. The HIG is the definitive reference for designing within the Apple ecosystem.
Why it’s notable: The HIG is extraordinarily deep — covering not just visual design but platform behaviors, interaction paradigms, accessibility expectations, and spatial design for Apple Vision Pro. It’s updated regularly with each major OS release.
What you can learn: Platform-specific design thinking. Apple’s guidelines show how components should adapt their behavior (not just layout) across devices and input methods — touch, mouse, keyboard, eye tracking, and hand gestures.
Explore: developer.apple.com/design/human-interface-guidelines
5. Atlassian Design System
What it is: Atlassian’s design system powering Jira, Confluence, Trello, Bitbucket, and their broader product ecosystem. Built on a token-first architecture with comprehensive React components.
Why it’s notable: Atlassian’s system demonstrates how to unify a diverse product portfolio under one design language. Their token system is semantic (e.g., color.text.brand rather than blue-700), which makes theming and multi-product consistency cleaner. The pattern library includes complex enterprise patterns like empty states, onboarding flows, and feature flags.
What you can learn: How to implement semantic design tokens and how to handle multi-product consistency when each product has distinct workflows but needs to feel unified.
Explore: atlassian.design
6. Salesforce Lightning Design System
What it is: Salesforce’s design system for building enterprise applications on the Salesforce platform. Lightning includes a component library, design guidelines, and a comprehensive set of utility classes.
Why it’s notable: Lightning is designed for extremely complex, data-heavy enterprise UIs. Its approach to handling forms, tables, record pages, and workflows at enterprise scale is unmatched. The system also includes blueprints — full page templates for common Salesforce use cases.
What you can learn: How to design for enterprise complexity. Lightning’s patterns for data tables, record detail pages, and form layouts are directly applicable to any B2B SaaS product.
Explore: lightningdesignsystem.com
7. Microsoft Fluent 2
What it is: Microsoft’s cross-platform design system used across Microsoft 365, Windows, Teams, and Azure. Fluent 2 is the latest evolution, emphasizing simplicity, consistency, and cross-platform coherence.
Why it’s notable: Fluent 2 supports an enormous range of platforms — web, Windows, iOS, Android, and macOS — with component libraries for React, React Native, and native frameworks. Its approach to cross-platform consistency while respecting platform conventions is highly sophisticated.
What you can learn: How to build a system that spans desktop, mobile, and web without forcing every platform to look identical. Fluent 2’s use of shared tokens with platform-specific component implementations is an excellent model.
Explore: fluent2.microsoft.design
8. Ant Design
What it is: An enterprise-class React UI library and design system maintained by Ant Group (Alibaba). One of the most widely used component libraries in the React ecosystem, especially popular for admin interfaces and B2B products.
Why it’s notable: Ant Design provides an extensive component library (60+ components) with a consistent API, built-in internationalization, and strong TypeScript support. Its ProComponents (pre-built page-level components like ProTable and ProForm) show how a system can provide higher-level building blocks beyond primitive components.
What you can learn: How to build a developer-focused design system where the component API is as carefully designed as the visual language. Ant Design demonstrates the value of offering both low-level primitives and composed, page-level patterns.
Explore: ant.design
UXPin offers Ant Design integration so you can prototype with the exact same components your developers use in React.
9. shadcn/ui
What it is: A modern, open-source collection of reusable React components built on Radix primitives and styled with Tailwind CSS. Unlike traditional component libraries, shadcn/ui uses a copy-paste model — you own and customize the source code rather than importing from a package.
Why it’s notable: shadcn/ui has become one of the fastest-growing UI component collections in the React ecosystem since its 2023 launch. Its approach of giving developers full ownership of component code — rather than hiding it behind a node module — appeals to teams that want complete control over customization. The components are accessible by default (built on Radix), beautifully designed, and easy to theme.
What you can learn: The copy-and-own distribution model as an alternative to traditional npm packages. shadcn/ui demonstrates that a design system doesn’t need a heavy runtime — you can deliver high-quality, accessible components through a CLI that copies source files directly into the project.
Explore: ui.shadcn.com
UXPin supports shadcn/ui components through Merge, letting designers prototype with the same accessible, Tailwind-styled components developers use in production.
10. Porsche Design System
What it is: Porsche’s design system for building web applications that meet Porsche’s exacting quality and brand standards. It includes design foundations, Web Components, and libraries for design tools.
Why it’s notable: The Porsche Design System is a benchmark for premium brand design systems. Every component is meticulously built and tested against Porsche’s rigorous quality standards. It uses Web Components for framework-agnostic delivery.
What you can learn: How to translate a luxury brand’s identity into a functional, scalable design system. Porsche’s approach to maintaining brand precision at the component level — without sacrificing developer experience — is a model for any brand-sensitive organization.
Explore: designsystem.porsche.com
11. Uber Base
What it is: Uber’s design system used across rider, driver, delivery, and freight products. Base includes a React component library (Base Web), design foundations, and platform-specific guidelines.
Why it’s notable: Base Web’s “overrides” pattern is an elegant approach to component customization — allowing teams to deeply customize any part of a component without forking. The system also demonstrates how to handle complex theming across distinct product brands (Uber, Uber Eats, Uber Freight) within a unified component architecture.
What you can learn: The overrides customization pattern and how to build a single component library that serves multiple distinct brands with different visual identities but shared interaction patterns.
Explore: baseweb.design
12. GitLab Pajamas
What it is: GitLab’s design system used across the entire GitLab product. Pajamas includes design foundations, Vue.js components, and comprehensive UX guidelines.
Why it’s notable: Pajamas is built entirely in the open (like GitLab itself). Every design decision, component discussion, and system change happens in public GitLab issues and merge requests. The system includes a “component lifecycle” process that’s one of the most transparent governance models in any design system.
What you can learn: How to manage a design system with full transparency and community involvement. GitLab’s public contribution process and component status tracking are excellent models for open-source design system governance.
Explore: design.gitlab.com
13. Adobe Spectrum
What it is: Adobe’s design system used across Creative Cloud, Document Cloud, and Experience Cloud products. Spectrum supports web, iOS, and Android with a focus on professional creative tools.
Why it’s notable: Spectrum handles an unusual design challenge — building a system that works for both content creation tools (Photoshop, Illustrator) and content management tools (Experience Manager, Analytics). Its inclusive design principles are thorough, and the system includes guidance for complex UI patterns like canvases, toolbars, and property panels.
What you can learn: How to build a design system for complex, professional-grade tools. Spectrum’s approach to density variations (comfortable, compact) and complex interaction patterns for creative tools is highly valuable for teams building sophisticated applications.
Explore: spectrum.adobe.com
14. Radix
What it is: An open-source component library providing unstyled, accessible UI primitives for React. Radix separates behavior and accessibility from visual design, giving teams full control over styling while handling the hard accessibility and interaction work.
Why it’s notable: Radix has become the accessibility backbone powering many popular UI libraries — including shadcn/ui. Its headless approach means components handle keyboard navigation, focus management, screen reader announcements, and ARIA attributes out of the box, while teams apply their own visual design. The Radix Themes layer adds a curated design on top for teams that want both.
What you can learn: How to build accessible component primitives that separate behavior from presentation. Radix is the gold standard for headless component architecture, and studying its API design teaches how to make accessibility invisible to consumers while keeping it bulletproof underneath.
Explore: radix-ui.com
15. Goldman Sachs GS Design System
What it is: Goldman Sachs’ design system for internal and client-facing financial applications. One of the few publicly shared design systems from the financial services industry.
Why it’s notable: The GS Design System demonstrates how a traditionally conservative, highly-regulated industry approaches systematic design. Its patterns for data-dense financial interfaces — tables, charts, real-time data displays — are particularly well thought out. The system emphasizes clarity and information density while maintaining accessibility standards.
What you can learn: How to design for data-heavy, compliance-sensitive environments. The GS Design System’s approach to information density, table design, and financial data visualization is applicable to any product dealing with complex, numbers-heavy interfaces.
Explore: design.gs.com
How to Apply These Lessons to Your Own Design System
Studying these examples is valuable, but the real payoff comes from applying what you learn. Here’s how to put these insights into practice:
Start With Tokens, Not Components
Every strong design system on this list starts with design tokens — the foundational values for color, spacing, typography, and elevation. Define semantic tokens (e.g., color.text.primary rather than gray-900) so your system supports theming from day one.
Treat Your System Like a Product
The best systems above all have something in common: they treat the design system as a product with its own roadmap, governance, backlog, and contribution model. Publish a lightweight governance process and a public changelog so consuming teams trust updates and know how to propose improvements.
Bridge the Design-Code Gap
The most impactful systems are the ones where design and code stay in sync. With UXPin Merge, you can bring your production React components directly into the design environment — so designers prototype with the exact same components developers use in code. This eliminates the handoff gap and ensures what’s designed is what gets built.
Teams can also use UXPin Forge to generate fully interactive prototypes from text prompts, with AI output constrained to your actual design system components. Forge handles the initial 80% of layout and composition work, while professional design tools handle the final 20% of refinement. The output is production-ready JSX — no handoff gap.
Use an Existing System as a Starting Point
You don’t have to build from scratch. UXPin supports several popular component libraries out of the box:
Any of these can serve as a foundation that you customize with your brand’s tokens, patterns, and guidelines.
Design System Challenges and How to Solve Them
Even well-intentioned design systems face common challenges:
- Adoption resistance — Teams won’t use a system they don’t trust. Publish a changelog, maintain backward compatibility, and involve consuming teams in roadmap decisions.
- Design-code drift — When design tools and code diverge, teams lose confidence. Code-backed design tools like UXPin Merge solve this by keeping both environments on the same component source.
- Scaling governance — As more teams contribute, decision-making slows down. Define clear roles (system team vs. consumers), establish review SLAs, and publish contribution criteria upfront.
- Documentation fatigue — Documentation that’s never updated is worse than no documentation. Automate where possible (auto-generate prop tables from code) and keep guidelines focused on decisions, not descriptions.
- AI compatibility — In 2026, design systems also need to work with AI design tools. Systems with well-structured component APIs and clear Design System Guidelines enable AI assistants like UXPin Forge to generate on-brand output that respects brand rules automatically.
Frequently Asked Questions
What is a design system?
A design system is a collection of reusable components, design tokens, guidelines, documentation, and code that teams use to build consistent, on-brand user interfaces at scale. It serves as a single source of truth for designers, developers, and product managers.
What is the difference between a design system, a pattern library, and a style guide?
A design system is the full stack — principles, tokens, components, code, accessibility rules, and governance. A pattern library is a subset containing reusable UI patterns and usage guidance. A style guide covers brand and visual language (color, type, tone) but typically does not include components or production code.
What are the best design system examples in 2026?
Top examples include Google Material Design 3, Shopify Polaris, IBM Carbon, Apple Human Interface Guidelines, Atlassian Design System, Salesforce Lightning, Microsoft Fluent 2, Ant Design, shadcn/ui, Porsche Design System, Uber Base, GitLab Pajamas, Adobe Spectrum, Radix, and Goldman Sachs GS Design System.
How do I evaluate whether a design system is well built?
Evaluate across eight dimensions: component coverage, documentation clarity, accessibility support, code delivery and framework support, theming and design token architecture, governance model, contribution process, and evidence of real-world adoption in shipped products.
How do I start building a design system?
Start with a UI audit to identify recurring components and inconsistencies. Define design tokens (color, spacing, typography scales), build a small set of core components, document usage guidelines, and establish a governance process. Tools like UXPin Merge let you bring coded React components directly into the design environment, keeping your system in sync with production code.
Can I use an existing open-source design system instead of building my own?
Yes. Open-source systems like Material Design, Ant Design, shadcn/ui, and Radix provide production-ready components you can adopt or customize. Many teams start with an existing system and extend it with custom tokens and patterns to match their brand. UXPin supports libraries like MUI, Ant Design, and shadcn/ui out of the box through Merge.
Found this useful? Share with
